Cooling Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2008, 12:11 PM
Cooling Question
I pulled the ac/heater blower unit box thingamajig out of my 87 Monte Carlo and put in a 383 and TH350. My question is can i just connect the two coolant lines that go to the heater core. I have heard people just blocking the ports, but i thought that the heater core and lines were important because when the thermostat is closed, thats where the coolant flows and circulates.
Old 02-26-2008, 01:24 PM
Jmark's Avatar
You can loop them together or block them off, won't make any difference in flow.
Old 02-26-2008, 01:35 PM
You'll have to cut and try, some SBCs are really sensitive to the heater circuit as a bypass, others are not. In theory, there is a bypass hole below the the right side water pump mounting horn. This is supposed to provide a bypass when the thermostat is closed. It often is insufficient to keep the pump from cavitatng and hot spots from local boiling. The pass through the heater or a simple bypass loop without the heater insures this won't happen.
Bogie
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Cooling question oregon chevelle General Rodding Tech 14 02-06-2006 09:14 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
