Originally Posted by bigdog7373
Not true at all. Mechanical fans stop spinning while at cruising speed.
Still not the whole story. Centrifugal fans (the ones with a clutch in them) do slow down at speed but a true mechanical fan is solidily bolted to the water pump.
A thermostatically controlled fan should keep you cool. You can always install 2 of them with higher capacity later if you need it.
