Cooling question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2012, 09:47 AM
Last journal entry: Volkswagen V8 Squareback project.
Cooling question
I am building a tube chassis, sbc 350, 700R4, narrowed 9' Ford rear 1969 VW Squareback station wagon. I will also be running A/C. Question I have is this. I have a new aluminum radiator (fits 78-80 Camaro) with an electric fan/shroud that puts out 1800 CFM The car will probably weigh in at about 2,500 pounds. My question is. Can I just ran this fan only, without a water pump fan? Mainly due to room restrictions.
Old 08-12-2012, 04:57 PM
bigdog7373's Avatar
Of course it's fast
Yes, lots of guys run an electric fan only. Get a temperature controller though, do depend on yourself turning of a toggle switch like some guys do.
Old 08-12-2012, 06:10 PM
Why not just run the fan all the time ? After all a mechanical fan runs full time !
Old 08-12-2012, 06:31 PM
bigdog7373's Avatar
Of course it's fast
Not true at all. Mechanical fans stop spinning while at cruising speed. Running an electric fan all the time will use more power than a mechanical fan because of the elctrical draw on the alternator
Old 08-13-2012, 07:45 AM
Fan
Thanks for the replies about the cooling fan. So, if I use a thermostatically controlled fan switch, that should be all I need? No mechanical fan,right?
Old 08-13-2012, 08:02 AM
RWENUTS's Avatar
Still not the whole story. Centrifugal fans (the ones with a clutch in them) do slow down at speed but a true mechanical fan is solidily bolted to the water pump.
A thermostatically controlled fan should keep you cool. You can always install 2 of them with higher capacity later if you need it.
Old 08-13-2012, 08:45 AM
bigdog7373's Avatar
Of course it's fast
It would be a good idea to use a shroud too. What size fan is it?
Old 08-13-2012, 08:55 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Good shrouding is absolutely needed as a lot of cooling issues come from lack of airflow to the radiator and also allowing for evacuation of hot air from the engine compartment..You may spend a lot of time designing and fabricating the radiator shroud..
Sam
Old 08-13-2012, 09:32 AM
Correct, but be aware of what you are buying. Here are examples of the kits. The BE Cool kit is the best user friendly. I have the BE Cool kit installed on my 1967 Camaro with no problems in 3yrs. Compare - SummitRacing.com
Cooling Question mightycarlo10 Engine 2 02-26-2008 01:35 PM
cooling question wayneair Engine 11 05-07-2007 07:29 PM
cooling question 62chevystepside Engine 9 04-09-2006 04:46 AM
Cooling question oregon chevelle General Rodding Tech 14 02-06-2006 09:14 PM
Cooling question THADD Hotrodding Basics 8 01-25-2006 04:45 PM
