Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cooling question
Old 05-04-2007, 06:39 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
doc here,
A 305 radiator will cool a 350 Engine just fine....Provided both were stock, and used for normal street driven applications.
HOWEVER, This is not your case..you will/Should Need to upgrade the cooling system to meet the needs of your Performance engine.
Besides that, you have no idea of the internal condition of the old radiator, or any idea of it's past abuses..It may just blow apart when you least expect it.
Cheaper to do it now, than it will be when the gauge hits 260 degrees..
Doc
