Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cooling SBC
Thread: Cooling SBC
Old 05-11-2010, 02:20 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
Sounds like at higher speeds it is unable to get hot air out of the engine compartment fast enough. You could try a chin spoiler under the bottom of the radiator/core support like modern cars have(usually rubber), this creates a low pressure area behind the spoiler helping to draw the hot air that has come through the radiator out the bottom of the compartment.
Are you running a vacuum advance on the distributor?? Vacuum advance creates cooler running at cruise speeds.
