cooling system - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2012, 05:59 PM
cooling system
have a 2000 montana, the fans will only operate if you turn on the ac. sometime you can turn ac off and they will still operate till shut off or next driving cycle. with ac on always then they run as needed, from slow to high speed. ideas???
Old 01-30-2012, 04:02 AM
EOD Guy's Avatar
Might be the ac cut-in relay sticking or going bad. Just a guess tho'
Old 01-30-2012, 06:44 AM
T-bucket23's Avatar
Wiki Edits: 26
Temp sensor. put a scan tool on it and see what the ecm thinks the engine temp is. Could also possibly be a bad relay, some vehicles use a seperate relay for fan control from temp and A/C activation
Chet
Old 01-30-2012, 04:22 PM
Joe G's Avatar
For what it's worth, I had the same problem on an '01 Ford - Radiator fan only came on with the AC. Turned out that they used a resistor similar to a heater blower resistor (only larger), to get the fan to run in it's low speed mode. My resistor was fried, so the only time the rad fan would work was in high mode. Furthermore, on my car, the ECU would never 'tell' the fan to run on high based on engine temp, even when it was in excess of 250 degrees. In my case, the only time the fan ran on high was when the AC 'requested' it to.
My rad fan speed resistor was mounted in the radiator fan shroud and was very easy to change.
There's a good chance that GM wires their radiator fans completely different than Ford does, but since the symptom sounded similar, I figured I would throw it out there for consideration.
It would be an easy thing to check.
Hope this helps....
Joe G.
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 07:34 PM
Cooling system smokin63 Engine 2 12-18-2007 06:26 PM
air in cooling system markiemyster Engine 5 03-04-2006 03:34 PM
Air into the cooling system. TVR383 Engine 7 04-11-2003 02:54 PM
Cooling system nd500 Engine 2 03-16-2003 02:57 PM
