Cooling system - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2013, 01:21 PM
Cooling system
I have just replaced a thermostat the bottom hose leading to the thermostat housing and had to use a Polly to seal the thermostat housing when i started the car and let it heat up i had water coming from my cap the thermostat is new and just after replacing it i noticed a leak in my hose this is when i changed it that when the car had water coming out from the cap. do i have air in the engine or do i have to replace the thermostat again
Old 02-23-2013, 01:25 PM
malc's Avatar
Living At The Speed Of Life
I think you ought to re read your post and modify it.
It´s hard to understand.
You´ll also have to post up what vehicle you´re working on.
how do i use the bleeder
cooling system BRIANW Engine 3 05-15-2012 03:35 AM
cooling system esproles Engine 2 04-17-2012 04:56 PM
cooling system cdmiller Electrical 3 01-30-2012 05:22 PM
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 08:34 PM
Cooling system nd500 Engine 2 03-16-2003 03:57 PM
