cooling system blowing chunks - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2006, 11:30 AM
Hellbilly Hotrods
ok, i know its been a while since ive been around. its cause ive been way too busy in the shop.
i came upon a new problem today. i keep blowing out parts on my cooling system .
Car:
1988 Corvette race car.
Stock radiator, radiator hoses, routing 16 LB cap. no heater core, interior, smog, anything.
Engine:
383 stroker L98. Pro topline heads, Victor Jr. Water pump. TPI Specialties intake.
we just took out the AC, etc. gutted the car. have not taken out the dash and heater box yet. i was out using it to chase parts, and blew the rubber cap off the intake manifold heater hose fitting twice. hooked up the heater core, blew it apart.
thermostat is not sticking. temp between 180-200 degrees farenheight.
what is going on here?
can i just put steel plugs in both heater hose fittings and be done with it, or will i pop the radiator next?
any help would be nice. got to have it to kershaw on friday.
Michael
Old 02-27-2006, 02:58 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Sounds like head gasket to me.
Old 02-27-2006, 03:28 PM
50 chevy p/u's Avatar
autoglass master tech
Check to see if the rad cap is ok.
Old 02-28-2006, 08:36 AM
Hellbilly Hotrods
head gaskets are fine. passed the leakdown, and there is no oil in the water or water in the oil.
im suspecting the cap. im waiting for it to cool down (bleeding the system again) and then putting a fresh 13 lb cap on it.
well see what happens. cross your fingers.
Michael
Old 02-28-2006, 08:56 AM
Pressure is going somewhere, a leak down doesn't always fiind the culprit becuase of the low pressures at room temp. Gasket's can still leak at the typical 5000 PSI they must endure but not at the measly 100 pounds your air line put's on it.
If a cap were bad, it'll either not open at all or open too earlier than the rating on the cap. If it opens too early you have too much pressure in the system for the cap. A 16 pound cap is norm. Blowing off hoses takes a lot more than 30 pounds of pressure. So if the cap didn't open at all, you still have too much pressure in the system. Using a 13 pound cap means all your water will go out the cap instead of blowing hoses off. This is good, however, you shouldn't be blowing water out of the cap either.
No harm in changing caps at all, they go bad pretty easily, the rubber gasket get's dirty and destroyed eventually. You still need to find out why there is so much pressure is in the system.
Try running the engine without the cap on and look for bubbles. Big bubbles. big enough to push water out the cap. It's a pretty sure sign a head gasket is leaking.
Good luck.
Old 02-28-2006, 09:56 AM
Hellbilly Hotrods
if you drive the car normal, we have no problems. if you run it up to 6500, thats when things start to break.
we havent noticed any big bubbles. and my employee informed me today tat he may have accidently nicked the old heater core with a sheetmetal screw when he put it through the firewall.
so we ot the new cap on. im gonna go beat the piss outta it and see what happens.
Michael
Old 02-28-2006, 01:26 PM
6000 is a lot of pressure!
2500 is not so much
Old 03-01-2006, 07:21 AM
Hellbilly Hotrods
fised it. bad cap.
wow, that was an odd one.
Michael
Old 03-01-2006, 09:24 AM
Watch for you lower Rad cap pressure purging water out the overflow. You'll know because the tank stay's too full or if you don't have one you'll be adding water periodically.
Glad you got it fixed though.
Cooling System Flush 73oldsman Engine 2 02-13-2006 07:31 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
Cooling System Woes chadzeilenga Engine 10 09-14-2005 12:40 AM
Cooling System Gurgle Festive57 Engine 3 08-25-2005 10:51 AM
Cooling Fan for 6 volt system flatheadharold Electrical 2 09-01-2004 09:31 AM
