Cooling system and heater questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2012, 07:20 PM
I put a mini heater from summit up under the dash in my 48 chevy and had a couple questions about coolant flow to the unit. I do not have ac so I want to put an inline shut off valve under the dash to keep the hot water from circulating through the heater core when I do not need it. Should I put the shut off valve in the line coming from the water pump? Will this disrupt flow for the rest of the engines cooling system if it has a dead spot under the dash? I thought it would all be good but just wanted to make sure before I go ahead, thanks!
Old 05-28-2012, 08:57 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
shut off valve
i did the on my vette. i put my valve on the line right at the intake port. this way i didn't have to put my arm down in the engine compartment. valve was up by the alternator. i used a ball valve. on semi cool nights i could regulate it to be comfortable in the car.
Old 05-28-2012, 10:04 PM
Ok thanks and while I am here, does anybody know what type of fittings or hoses I can use to connect the threaded end of the bulkhead to the water pump and intake manifold inlets and outlets? The other side is easy with 5/8" heater hose under the dash. Thanks
cooling system BRIANW Engine 3 05-15-2012 02:35 AM
cooling system cdmiller Electrical 3 01-30-2012 04:22 PM
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 07:34 PM
Cooling system smokin63 Engine 2 12-18-2007 06:26 PM
350 heater hose cooling question 72Nova383 Engine 1 09-16-2004 09:43 AM
