-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Cooling System-Open System vs Closed System (http://www.hotrodders.com/forum/cooling-system-open-system-vs-closed-system-153317.html)
smokey626 02-13-2009 03:13 PM
What is the difference between an open cooling system and a closed system? On my Luv, I need for the radiator to burp coolant into the overflow tank, and draw it back in when it needs it. Which system do I need, as I know I have to buy the right cap for that to work. Thanks!
Smokey
http://s294.photobucket.com/albums/m...okeyfiremedic/
crownver 02-13-2009 09:46 PM
Instead of puking coolant out the hose onto the ground in an open system, on a closed system it drains into the reservoir, and then gets sucked back into the rad on cooling.
NEW INTERIORS 02-13-2009 10:21 PM
Smokey
You have to have a Recirculating/Overflow Catch Can ...(Not just a catch can).. :thumbup:
smokey626 02-14-2009 06:27 PM
Okey dokey, thank you all, that cleared that up!! The catch can I'm using is a recirculating type, so says the Summit guru!
timothale 02-14-2009 07:34 PM
open sustem
My 1922 antique model T racer has an open system, no pressure cap and if it gets hot it spits out coolant. A pressuer system increades the cooling efficiency.
