What is the difference between an open cooling system and a closed system? On my Luv, I need for the radiator to burp coolant into the overflow tank, and draw it back in when it needs it. Which system do I need, as I know I have to buy the right cap for that to work. Thanks!
Instead of puking coolant out the hose onto the ground in an open system, on a closed system it drains into the reservoir, and then gets sucked back into the rad on cooling.
My 1922 antique model T racer has an open system, no pressure cap and if it gets hot it spits out coolant. A pressuer system increades the cooling efficiency.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
