Copper gaskets whats the differance. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2007, 08:26 PM
charger528's Avatar
I have purchased a set of copper head gaskets the same ones used on a top alcohol motor.
due to the thickness need .080 to correct comp to run on 93 pump gas.
the block was decked .020 or .030 in a previous build and the pistons i used would make the comp to high see (update 528 stroker motor)
my question is will these gaskets be a problem they are sce pro copper gaskets and are listed for extreme street and bracket use??
am i asking for trouble
Old 10-06-2007, 09:09 PM
Wiki Edits: 31
kinda. your quench will be off a bit, w/ the extra thick gasket. but the real problem is, copper gaskets don't seal off water, so you'll need to o ring the block. or have the tops of the pistions milled enough, that you can use a standard gasket, but even that's risky
Old 10-06-2007, 09:20 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Or, you could dry deck the block. (Plug the water passages between the block and heads)
Old 10-06-2007, 09:43 PM
Wiki Edits: 31
that would raise the comp, correct the quench yes, but accomplish nothing for comp ratio reduction.
Old 10-06-2007, 10:28 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
The O'Ring's would only seal the compression area of the gasket. Street-able? Possibly! I use Coppercoat by Permatex around the water ports. It's marginal at least.
Old 10-06-2007, 11:19 PM
charger528's Avatar
Thanks guys i just went on line with jeggs and ordered fel pro gaskets .051 i guess i might have to run a octane booster.
but on another note i have ran 11-1 on the street with iron heads before with careful tuning and tailored advance curve in my distributer on 93 octane
I new very little about copper heads thought they were just a bolt on
and didn't think of quench the exact purpose that i bought close chambered heads in the first place.
crappy gas what a drag so worried about compression didn't take the time to res-each a product before i bought it.
oh well lessen learn kind of expensive but not as bad as hydro locking a engine.
besides if it were easy what fun would it be its all about the challenge to have something a Little different to think out of the box and most of all have fun.
when i think off what i spent already i cant amagine break or blow something right off the bat . I mean i just dropped anouther $800 tonight on a king demon 1090 carb ,$50 adapter and or corse $115 heads gaskets.
again thanks for adverting a near catastrophe. Bill
Old 10-07-2007, 01:13 AM
My 2 cents worth
Wiki Edits: 3
I just can't stand to see a Grown Man Cry. Glad to have been some help. There's nothing worse than having something you have worked on so hard Blow Up in your Face.
Happy motoring:
From All OF Us
Been There, Done That
Steve
Old 10-07-2007, 04:21 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Copper gaskets don't seal on their own. O-ringing helps to seal the compression around the cylinders, but the water passages must be sealed.
There are several ways to do it. Some currently-published techbooks tell you to paint both sides of the gasket with silver spray paint. It actually works quite well, but its not ideal. Many folks use copper spray-on gasket adhesive.
At any rate, something must be put on them to seal water.
Old 10-07-2007, 01:05 PM
Wiki Edits: 31
yea. could rig up a water/ alchahol injection system out of a washer fluid resivore and pump, w/ a smaller holley jet ( #61 or somthing ), spraying into the carb. use a NOS full throttle switch to turn it on. that will help detonation.
Old 10-08-2007, 07:10 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys - Out to Body and Paint
Wiki Edits: 2
Another option would be to use Hylomar sealant around the water passages. I used a thin spray coat on my copper SCE gaskets with good results so far. It also comes in tube form.
Steve
Old 10-08-2007, 07:34 AM
RippinRon's Avatar
What exactly are the specs of your engine? You never really said in your previous post.
Old 10-08-2007, 08:44 AM
RippinRon's Avatar
With a
4.36" bore
4.375" stroke
84 cc chamber
.051" head gasket with 4.59" bore
deck clearance of -.0205 (above deck) assuming the deck height is 10.69 (.030" off 10.72")
4cc flat tops (1.423 c.h./ 7.1" rod)
I get a 12.05:1 static compression ratio. With the comp xe285hl cam you dynamic compression ratio will be too high. I would run a magnum 305h and that would give you a dcr of 8.15 right in the range (8-8.4) for pump gas. Your engine is much larger than the 440 that the cams rpm range is based on so it will seem like a smaller cam.
BBC Copper head gaskets O-ringed block dgcantrellsr Engine 1 04-24-2007 05:21 PM
copper exhaust gaskets......HELP!!!! trick66 Engine 11 12-10-2006 10:12 AM
More garage wiring questions grouch Garage - Tools 26 06-11-2005 11:23 PM
? about copper head gasket's bowtieorbust Engine 21 08-15-2004 10:49 PM
Copper gaskets S10Fan Engine 1 05-06-2004 07:04 AM
