Copper head gaskets and O-rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2008, 10:09 AM
A quickie:
Are copper head gaskets an absolute MUST with an O-ringed block?
If not, any tricks needed to keep a "standard" gasket leak free? Any recommended brand to use?
Chevy 454 and performance oriented use in mind, of course.
Old 03-05-2008, 11:31 AM
techinspector1's Avatar
Wiki Edits: 326
If you use o-rings with a standard gasket, the fire ring of the gasket will line up with the o-ring. The o-ring cannot compress into the fire ring, so the head will stand up off the block deck and fail to seal the water passages. Measure how far the o-rings are above the deck and use that as a guide to the copper gasket thickness you'll need. Most manufacturers will recommend about 10%. In other words, if the ring is 0.004" above the deck, then you would want to use a 0.040" thick gasket. If, for instance the ring is 0.010" above the deck and you try to use a 0.040" gasket, there will be an insufficient amount of material to move around when the ring starts compressing into the copper material of the gasket and you'll probably get the head stand-off mentioned above.
