copper or not - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2006, 10:30 PM
copper or not
Hi guys,
A friend of mine has a 440 with mods. His concern is the header gaskets. He was wondering about the advantages of copper or if there is a better type out there?
Thank you for your time...
Old 03-31-2006, 10:46 PM
Wiki Edits: 31
many find that factory exhaust manifold gaskets work best
Old 04-01-2006, 08:29 AM
MI2600's Avatar
Member# 3287
I use the factory style gaskets w/o any problems. I think a lot of the problems people have are caused by warped flanges.
copper exhaust gaskets......HELP!!!! trick66 Engine 11 12-10-2006 11:12 AM
Banjo crush washers: copper vs alum? Dan B Suspension - Brakes - Steering 7 01-15-2006 08:19 AM
More garage wiring questions grouch Garage - Tools 26 06-12-2005 12:23 AM
Copper okay for trans cooler line? cboy Transmission - Rearend 10 05-06-2005 11:16 PM
Using copper pipe for heater lines Jag Daddy Engine 1 02-09-2004 06:21 PM
