Copper vs MLS vs ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2008, 07:47 PM
Copper vs MLS vs ?
Hey guys, I'm new here, and I wanted to get some information head gaskets.
Really just polling, as I've been reading a bit on the different options, so MLS and copper are the main players? but what other options are there?
I'm curious for a future project!!
Old 11-10-2008, 08:36 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
We have a wiki page on this that might be helpful to you: Head gasket.
Old 11-11-2008, 05:49 PM
OHD's Avatar
OHD OHD is offline
Steel/composite head gaskets are good for a stock rebuild, less tahn 12.5 to 1, MLS are for higher compression and require both the head and the decks to have a very fine finish, Copper are for even higher compression and for oringed blocks/marine applications. If you use copper always coat them with either schlac(sp) or copper coat to seal the cooling passages.
Old 11-12-2008, 05:49 AM
Last journal entry: PICTURE TEST
gaskets
Give some more details about exactly what you are building.
Keith
All I see is copper... WsXs3 Engine 4 11-09-2006 10:43 AM
Copper Pipe Kenny G Garage - Tools 11 06-30-2006 08:51 PM
copper water lines Animal General Rodding Tech 20 03-21-2006 06:45 PM
More garage wiring questions grouch Garage - Tools 26 06-12-2005 12:23 AM
Using copper pipe for heater lines Jag Daddy Engine 1 02-09-2004 06:21 PM
