Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Corded tool care.
Old 12-10-2005, 08:16 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
you've hit most of the area's of concern
you can take a piece of 5/16 or 3/8 fuel line and put it around the cord to keep it from getting nicked at least at the ends
SR66
I'm not prejudice, I hate everyone
keep them clean and put up when not in use
when I buy a new drill or impact something that has parts that will rust is 1 ST think is to degrease that part of it and scuff it up w/ some scotchbrite and tape it off and paint if I use Yellow or clears the yellow works on 2 levels keeps the oxidation out and you know its mine
always lube air tools at the beginning and end of use sometimes in between
make a place for them so they get proper storage (so there not in a big box or bag at the bottom getting knocked around
hope this helps
SR66
"SlowRide66"
"Illegitimis non carborundum"
