Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Corded tool care.
Old 12-13-2005, 07:05 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
shcnitz
You might need to check the breaker on that service.
I had a 20 AMP running to my tool box and when the compressor kicked on the fluorescents would go out and flicker back on so I replaced it with 30 amp and the compressor kicks on and ups and runs faster and the lights dont go out.
If you dont know about AC current get some one who dose its tricky and can mess you up real fast
SR66
"SlowRide66"
"Illegitimis non carborundum"
