core/cork 14??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2004, 10:40 PM
53fordguy's Avatar
Junkyard Kustoms
Last journal entry: update after a long time
core/cork 14???
Can some one explain this to me and how much one is worth? Also what gear ratios came in them?
Is this one?
53 fords rule!
Old 10-19-2004, 05:11 PM
Tazz
Yep...thats a rear end allright!!
Pick up the rear end and put two jack stands under it...one on each side/or end and turn the brake drum and count how man times the universal turns around for every one revolution of the brake drum... That will tell you what the gear ratio is. Do you have any idea what it came out of?
Tazz
Rat Rods Rule!
Old 10-19-2004, 09:33 PM
53fordguy's Avatar
Junkyard Kustoms
i
its out of a 3/4 ton chevy
53 fords rule!
