Core size? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-22-2005, 06:04 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Add a 302, that will get it loud and throaty.
  #17 (permalink)
Old 06-23-2005, 12:06 AM
Mine's the Thrush 24214 and it's inside tube measures 2-1/2". Inlet & outlet are for 2-1/2" pipe. The inside tube is smoothly perforated with no protruding zits or louvers.
  #18 (permalink)
Old 06-24-2005, 11:32 AM
broncoII88's Avatar
Do the right thing...
2.9 to 4.0 or 302? Why not!
Isn't it true that those "louvers" will restrict flow? Yeah I thought about a 302 swap, but I've decided that if I was going to swap the motor, then I would drop in a 4.0L V6 instead. It will drop right in, I can use the same tranny and driveline, and I have more upgrades to choose from for the 4.0L. But thankyou all for your help.
  #19 (permalink)
Old 06-25-2005, 12:14 AM
Siggy_Freud's Avatar
Anything that protrudes into the path of air will restrict the flow to a degree. It will also add air turbulence. Some turbulence can be good when it deals with intake but for exhaust you pretty much want the gasses to flow as easily as possible.
Bringing history and technology together.
  #20 (permalink)
Old 06-25-2005, 09:12 AM
broncoII88's Avatar
Just the answer I was looking for siggy! Thanx.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 10:21 PM
Bore size question 53LEDSLED Engine 5 05-12-2005 07:55 PM
heater core Brian Morency Engine 6 08-27-2004 01:55 PM
Ever install a heater core in a chevy Van? tm454 Hotrodders' Lounge 6 04-04-2004 02:31 PM
S-10 tail pipe size catscan4free Engine 3 02-23-2004 03:34 PM
