Core size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2005, 06:50 PM
broncoII88's Avatar
Do the right thing...
Core size?
Does anyone know what the core size for a Cherrybomb or Thrush glasspack with a 2 1/4" inlet/outlet is?
Old 06-18-2005, 08:53 AM
broncoII88's Avatar
Core size means flow!
I'm thinking that the core size would match the inlet/outlet size correct? If the inlet/outlet was 2 1/4" ID, wouldn't the core be 2 1/4" ID?
Old 06-18-2005, 07:34 PM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
no. they get fat in the middle, like 3 or 4 inches. Dunno exact #'s.. never measured....take a tape measure to kragen and put it to use, they wont care.
Old 06-19-2005, 03:13 PM
broncoII88's Avatar
Tunnel vision...
Can you see the core enough to measure it? Also, should a glasspack have a perforated, not louvered core for max flow and a good sound?
Old 06-20-2005, 04:36 PM
stick you finger in the inlet and feel around. Get an idea of where its at then measure the outside with the tape measure.
Rotate 90 bend and cough.
Old 06-20-2005, 04:52 PM
broncoII88's Avatar
What ya talkin bout Willis?
Rotate 90 degrees, bend and cough?
Old 06-20-2005, 05:55 PM
joke that went right over your head.
insert finger and feel around?.....prostate exam........
next is the rest of the physical....turn to the side bend over and cough. LOL
well you asked
Old 06-21-2005, 01:52 PM
broncoII88's Avatar
Put that glove away!
Hopefully I won't need a prostate exam until I'm 50 and need a colinoscopy! I'll do that. Not bend and cough, but find a parts store that has a cherrybomb or thrush in stock then measure it to make sure it's the size I want before I order it.
Old 06-21-2005, 03:36 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Oh really
Can't resist..that colinoscopy deal involves a big long hose and drinking some real nasty tasting stuff to "clean you out"..
The they run that hose up your.....and all the time you are awake while they do this little deal..
See what you are in for when you get "old"
OMT
Now what was this thread about?????
Old 06-21-2005, 04:22 PM
broncoII88's Avatar
Glasspacks OneMoreTime. Glasspacks. I want to know if anyone knows what the CORE SIZE of a Thrush or Cherrybomb glasspack with a 2 1/4" ID inlet/outlet is.
Old 06-21-2005, 05:55 PM
Im curious, why is it so important to know? people put them on v8's (backpressure up the arse) so you know they will flow ok for yours.
Have you even stuck your finger in it yet then measured? Do it man, youll get an idea...more of an idea than any text so far...
I got another curious ? for ya.....why you buying packs for? I mean sure ive got glasspacks, but i shure wouldnt have bought them...they will get changed out when i rebuild my engine. Im leaving them because why fix something thats not broke,right....but i have been thinking of cutting them directly in half and using a flex pipe dropped before the axels.....doubt ill do it, thats mickeymouse crap.
Old 06-21-2005, 08:08 PM
Siggy_Freud's Avatar
Still havent decided on mufflers Bronco?
Bringing history and technology together.
Old 06-21-2005, 10:58 PM
I thought the 4"-diameter ones had a 2-1/4" core, but http://www.dynomax.com/documents/thrushglass.pdf says they're 2-1/2". I have one in a box somewhere, & if I can lay my hands on it tonight, I'll try to measure the inside tube.
Old 06-22-2005, 01:23 PM
broncoII88's Avatar
I bought a Thrush turbo, but I want to (when I get enough cash) add Pacesetter headers, a dynatech hi flow cat, and a glasspack on it. The turbo is ok, but I want more loud and throaty. I have a friend who has the same setup with a cherrybomb on a 2.8L, and it sounds awesome! No rice at all!
Old 06-22-2005, 04:40 PM
2.8.........i hadda 89 firebird with a 2.8 it was a v6.....it sounded like an oversized dirtbike (had a flowmaster and flow cat on it) didnt sound ricey though. but it never will get throaty and mean sounding, its too small of an engine........173 c.i.d. thats half of a 350 and 2 pistons short.....
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
Bore size question 53LEDSLED Engine 5 05-12-2005 06:55 PM
heater core Brian Morency Engine 6 08-27-2004 12:55 PM
Ever install a heater core in a chevy Van? tm454 Hotrodders' Lounge 6 04-04-2004 01:31 PM
S-10 tail pipe size catscan4free Engine 3 02-23-2004 02:34 PM
