I bought the powermaster 67293 - a 140 amp. The first one I got from summit was defective and sent back - it looked like it was a return item. I ordered a second one from Pace and have had no problems with it.
Alt..
Doc here,
Sounds like your going in the right direction.. You might want to take this time to evaluate your electrical system now also. Since you have added all these high draw items, check to be sure your existing wire gauge will support the new higher current draw. You may be losing some power there. Be sure you have a proper ground system ... battery cable to the block at or near the starter, a second cable from the block to the frame and two 10 gauge wires to one to the firewall and the other to the alternator mount. Use star washers and burnish paint and grease from the grounding areas. If the alternator mount is powder white, remove it and all hardware and sand or water blast it to semi shiny and reinstall, use aluminum wire bonding paste on all hardware and everywhere you have contact to the block (steel) you have electrolysis going on that will cut the alternator's ability to put out full charge. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| How to choose correct camshaft | Drag1racer | Engine | 0 | 07-08-2005 04:04 PM |
| will a 18 circuit GM universal Painless setup handle a 140 amp alt? | rick458 | Electrical | 3 | 02-27-2005 02:57 PM |
| 100 AMP Service In Garage Help | daveh | Garage - Tools | 9 | 02-27-2005 01:15 AM |
| Alt. not charging battery... help!!! | whytry | Electrical | 9 | 11-04-2004 11:35 AM |
| Alt Amp Question | BM Ride 85 | Electrical | 6 | 12-22-2003 01:03 AM |
