Correct connectors for GM OBD - '94 Corvette LT-1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2011, 05:45 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Clutter
I have a 16-pin ALDL connector used on a '94 Corvette LT-1 that needs to be wired correctly.
Here's a picture (of one wired correctly, not mine):
What I'm looking for is the part number of those brass connectors inside the plastic housing. NAPA or CarQuest or similar would be fine. I'd ask there, but they never seem to know little stuff like this.
And just for fun, here's the wiring schematic from chevythunder.com:
Old 02-17-2011, 07:13 PM
GM Dealers have a parts book that lists fittings connectors etc. You may have to buy 100 or so but they are avaiable. you will have more luck with an established dealer where the guys also speak books not only computer. Also might try Terminal Supply in Troy Michigan
Old 02-17-2011, 07:52 PM
OLNOLAN's Avatar
Pigtails
Hey Man, Check out the pigtails $15.00 for obd 1 or 2. You have to have the correct crimping tool and a pin insertion/removal tool to make you're own. Nolan
http://www.eficonnection.com/eficonn...ngineType.aspx
Old 02-18-2011, 08:16 AM
hduff's Avatar
Here's the page at EFI Connection. I have the correct crimping tool and the pin insertion/removal tool is just a small, flat blade.
http://www.eficonnection.com/eficonn...spx?ItemId=361
And the connectors are offered in two wire gauge sizes, 18-20ga and 20-22ga, I need the former, P/N 100-00138
Now that I have the "correct" name for these things< i can check at the dealer/NAPA and see what is available locally, or order from EFI Connection.
Thanks!
Old 02-18-2011, 08:17 AM
hduff's Avatar
A search of the TS website catalog turned up empty, but thanks for the link.
Old 02-18-2011, 09:22 AM
hduff's Avatar
And I never thought about this: the wrecking yards are full of pigtails.
Old 02-18-2011, 09:40 AM
OLNOLAN's Avatar
Yep
Yep, My current project harness got real mangled, burnt and cut. Some of the repair pigtails are relatively cheap, some are real expensive. I did a little junkyard hunting, but found no LT1 equipped cars locally. On a couple of the missing plugs I plan to just butt splice the wires together to save the bucks. I don't plan on taking it apart after I put it together. olnolan
Old 02-18-2011, 11:10 AM
hduff's Avatar
No parts store localy has these connectors. I wound up at the Chevy dealership where my cousin works at the parts counter.
They were not listed in his computers, but it seems that every dealership has some small parts trays of Delphi connectors that are not for sale to the general public. I found the connectors there, but I had to look through 20 trays and many of the connectors looked similar.
So, if you have a connector as an example, you should be able to find anything if they'll give you access to the Delphi parts trays.
And again, there's always the junkyard full of "pigtails", but I hate doing that.
Old 02-18-2011, 06:13 PM
hi
delphi part numbers...12110250 housing, 12129484 and 12129373 terminals, 12160437 secondary lock.
check mouser.com....electronics parts distributor, they show parts in stock.
you can enter those numbers in their search.
mark
valve adjusters bottom out before lash is correct how do u find correct pushrod lengt brandon meek Engine 3 02-03-2011 02:58 PM
Bulkhead Connectors JamesCowan Electrical 3 02-26-2008 08:23 PM
Sub Frame Connectors Fire83Bird455 General Rodding Tech 2 01-19-2006 08:43 AM
GM electrical connectors... zipfactor Electrical 5 10-23-2005 08:47 AM
Trim connectors olds37dude Body - Exterior 1 04-06-2005 06:28 PM
