Correct flex plate install on sbc with T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2013, 04:35 PM
Handler's Avatar
I have a new flex plate for my rebuilt SBC with TH350 and want to ensure its installed correctly. I think it's backward now. There are recesses in the flex plate that look as though they should protrude out toward the lug of the torque converter. Right now the protruding side faces the engine and when I slide the converter up against the flex plate there is a gap between the lug and the flex plate, the gap being the same as the depth of the recess. Do I have it backward? Thanks for your help.
Old 08-28-2013, 05:10 PM
BOBCRMAN@aol.com's Avatar
In a word... YES
Old 08-28-2013, 06:09 PM
Handler's Avatar
Thanks. Wanted to be sure.
Which is the correct way to install dist. center plate? MT71c-10 General Rodding Tech 3 01-16-2010 04:06 AM
Which flex plate do I need for a SBC 307? willys36@aol.com Engine 9 09-08-2009 02:34 PM
400 SBC flex plate tommer2 Transmission - Rearend 7 04-16-2007 11:06 PM
flex plate for '70 sbc w/ TH350 sabino56 Engine 4 08-04-2006 09:03 PM
400 sbc flex plate wilky70 Engine 6 01-12-2006 04:35 PM
