Correct idle speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2005, 10:26 AM
Correct idle speed?
Timing a '74 SBC 350 w/quadrajet. What is correct idle speed? Thanks for replys.
Old 11-12-2005, 10:30 AM
coldknock's Avatar
Is it a stock engine?
Larry
Old 11-12-2005, 11:19 AM
Yes, its stock except for a mild cam.
Old 11-12-2005, 12:48 PM
Wiki Edits: 31
should be about 800 in park, 750 in gear
Old 11-12-2005, 12:50 PM
Thanks, Matt
Old 11-12-2005, 07:33 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
650 Manual Transmission, 950 Automatic, curb idle, Fully warmed, Choke wide open. A/C off.
Doc
Old 11-15-2005, 01:45 PM
Mertz's Avatar
Not to confuse you further but my 72 350 should be at 600 auto and about 700 to 750 manual.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Performance cam with a 2 corner idle Holley DP 650 Mad Maggot Engine 15 08-02-2005 06:04 AM
Speed Demon 750 Want Run Right DTL504 Engine 4 08-02-2005 06:02 AM
gas dripping in venturi at idle cboy Engine 12 07-29-2005 05:47 PM
Q-jet high idle COCHEV Engine 6 06-29-2003 05:04 PM
