correct needles - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2013, 01:45 PM
CPR CPR is offline
correct needles
Greetings!
I'm doing some research to help someone working on an auto upholstery. They are working on a Pfaff 145 which uses the 190 series needles. Sewing leather is not a problem but the vinyl does present some issues, particularly the holes created by the needle being too large.
She switched from the 24 thickness to a 21 but still has the issue with the holes being too large. Of course, we're going to go with a thinner needle but am looking for needle size recommendations for automotive interior vinyl as well as needle manufacturer. Orange, Organ, Schmetz, Grosspeck(sp) etc.
Any advice is greatly appreciated. Thank you!
Old 03-28-2013, 02:19 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Any good quality needle is fine. All of the names you mentioned are fine. (BTW, Groz Beckert is the name you're looking for.) I usually use size 21 needles. Your problem might be your thread is too small. I use size 92, size 138, size 207 and size 270 polyester thread. To sew with size 207 and size 270 you would need a size 24 needle.
Old 03-28-2013, 02:27 PM
mrshotrod's Avatar
I had an issue like that as well, from what I've been told you can't use leather needles on vinyl. I went down to a 135 #18 needle, I think they said thats the smallest they come in for industrial/commercial machines, I haven't had a problem with that since. But keep in mind your thread size, upholstery thread may not fit in an eye that small. I think i have #69 nylon thread and its ok.
Here is an interesting link on leather needles
http://www.keysew.com//Webpages/Demo...of_leather.pdf
I have to go to an upholstery supplier for my needles, I'm pretty sure you can't buy these just anywhere.
Groz-Beckett is the brand I use I know singer makes some. I think this will help send you in the right direction.
7x23 needles JCAR Interior 3 11-16-2012 06:08 PM
valve adjusters bottom out before lash is correct how do u find correct pushrod lengt brandon meek Engine 3 02-03-2011 02:58 PM
sewing needles Dbodily Interior 4 06-02-2009 09:12 PM
Threads and Needles 58Apache Interior 8 06-21-2008 07:56 PM
Secondary needles? 87442lover Engine 1 01-22-2004 08:55 PM
