Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Correct Oil Pressure for SBC 350
Old 03-13-2005, 08:08 AM
f355bird f355bird is offline
If you had a guage that went to anything above 50 you should be fine. Your motor will probably run a max of 45psi. So if you had a 60,75,or 80 you should be just fine.
