Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Correct Oil Pressure for SBC 350
Old 03-14-2005, 02:12 AM
f355bird f355bird is offline
Yes with a mechanical oil pressure guage it will have a vinyl plastic tube that runs from the oil sending unit up to the guage. Dont worry about it leaking or breaking. Ive ran numerous ones in different cars and never had a problem. You can buy an electric on if you want. Make sure to use some teflon tape on all the threads. Just make sure to double check things after it builds up pressure and then again after you drive it a couple of times to make sure.Its less than 10 dollars difference and the all you have to do is swap senders and wire it up. Its all up to you but either one will be fine.
