Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Correct Oil Pressure for SBC 350
Old 03-14-2005, 04:26 AM
RCastle's Avatar
RCastle RCastle is offline
Come Home Safe Soldier
Last journal entry: Headers
If you are concerned about the oil situation and running it into your car,get the copper tube that goes to instead of the nylon tube.Alsao put the rubber grommet into the passthru hole you will need to drill to run it inside the car. Mechanical oil pressure gauges are much better than the electric type. Make sure there are no kinks in whichever type of line you choose to run.Fuel presure gauges are what you need to be concerned about. There are two differnt style fuel gauges,one moubnnts outside of the vehicle. The style for routing inside of the car has a block that mounts outside.Your line runs to it,it allows the pressure to then send an accurate reading to either a electric signal or a different type of non-flammable liquid,thus not allowing the firey stuff in the cabin area.
