Correct Speedometer Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 11:41 AM
I have a 350 turbo coupled to a chevy 12 bolt with 3:73 gears and 15 in tires. my cars a 67 camaro the motor and trans came out of a 84 chevy. The speedo gear needs to be changed out. What tooth count and color would I need to correct how off the speedometer is? Thanks
Old 03-17-2012, 10:26 AM
SSedan64's Avatar
You're gonna also need the Tire Dia. to figure that out.
Info >> http://www.chevellestuff.com/tech/speedo.htm
Old 03-17-2012, 07:44 PM
Cape Cod Bob's Avatar
Heres some sites to help' You may need a calculator.
http://www.transmissioncenter.net/sp...____va.htm#350
http://chevelleengineer.home.comcast...eer/speedo.htm
http://www.riversidegear.com/muncie-...-driven-1.html
Old 03-17-2012, 08:26 PM
Wiki Edits: 85
If you know how far off the speedometer is, all you need to do is correct your speedo gear by that much. If you don't know, then you need to use the calculators provided to get an estimate of the correct gear ratio and gears.
correct distributor gear with roller cam aldfaa Engine 4 10-13-2010 10:02 PM
T-400 Speedometer gear changes Torque454 Transmission - Rearend 2 08-09-2010 11:45 AM
speedometer gear Blob Transmission - Rearend 3 07-17-2005 04:22 PM
Correct Gear Ratio MrRedDogSF Transmission - Rearend 11 04-29-2005 08:37 PM
speedometer gear 1986 Trans am Transmission - Rearend 2 10-26-2003 02:00 AM
