Correct stall speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2008, 07:50 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Correct stall speed
Hi all,
I'm currently running a 355 small block and 350 turbo with a 2500 stall and 4:11 gear. My idle RPM is 1000. Rear tires are 275-60-15.
I just built a 700R4 to swap out the 350 turbo. With the 700R4 trans the over drive gear ratio will change from 4:11 to 2:88. I need to know what stall speed will work properly. Since the engine RPM will be down in overdrive I'm worried if I don't pick the right converter it will be slipping in overdrive. Any thoughts on the stall speed??? This is just a 69 Camaro street car.
Old 01-24-2008, 09:12 AM
Frisco's Avatar
Glad To Be Here
Originally Posted by 1930u
Hi all,
I was under the impression that the 700R4 trans used a "Lock Up" style converter. If this is correct; there will be no slippage when in overdrive.
Old 01-24-2008, 09:34 PM
1930u's Avatar
Yes I think you're correct but until the converter clutch locks it works like a regular converter?
Old 01-25-2008, 09:08 PM
Yes, it works just like a normal converter til the TCC (torque converter cluctch) locks..
what stall speed?? tinman386 Transmission - Rearend 6 07-15-2007 08:56 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
Torque converter ??? blacklotus Transmission - Rearend 2 10-12-2004 03:23 PM
Which Stall Speed Converter? joe brienza Transmission - Rearend 4 07-19-2004 09:04 AM
Stall speed/ Cam size GearHead69 Engine 2 06-11-2003 03:33 PM
