Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - correct steps?
Thread: correct steps?
  #23 (permalink)
Old 03-16-2013, 08:38 AM
tech69 tech69 is online now
put up or shut up
Originally Posted by 99tjadams View Post
Called more suppliers today, found two in the U.S. that will be back to me monday with quotes on PPG / Dupont Base. Called doug at SPI, will try again monday, hoping to go with thier primer and clear still, also found a supplier here if I decide to go with omni.
Took a bunch more pics and made my photobucket private for viewing , its an album called paint and body work
Paint And Body Work Photos by 99tjadams | Photobucket
Hoping to get a more solid opinion on weather to strip all the paint or not.
get a backing pad for a buffer, cause you'll need a buffer later on after you paint. Then you can put 40 grit on your buffer with a slow speed and buzz that paint right off. Use a DA for roofs and decklids. Using a DA on that whole car will take forever.
