Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Correct Timing Chain Tension
Old 09-18-2005, 01:38 PM
tattoo3 tattoo3 is offline
Thats the way its supposed to be, I know the one you took off had lots of play, but the new one should be tight. it will stretch in just a few miles. I would suggest however that you take it back off until you have all the rotating assembly installed. I prefer to leave everything else alone until each cylinder is finished and fit just perfect. crank rods and pistons are the most important part of the motor.
have fun.
