-   -   Correct Timing Chain Tension (http://www.hotrodders.com/forum/correct-timing-chain-tension-70376.html)
mouseman 09-18-2005 11:30 AM
Hello,
I need some expert advice.
For a week now, I have went through two timing chains because of listening to what someone else said. I am not sure they were right though.
I am rebuilding a sbc 350 with a 4bolt main. All the machine work was done by NAPA.
In any event, could someone tell me what the correct tension is suppose to be for a newly installed double roller timing chain?
In my case, when I hung the chain on the crank sprocket/w camshaft sprocket attached, it bolted right up with no problem. I installed it "dot to dot." That is not advance or retarded, I just left it at the manufacturer setting.
Now that it is installed(I do not have any pistons in yet, just crank and cam), I can spin the crank freely without any binding in the timing chain or anywhere else. The problem is that the chain itself it tight, no play whatsoever unless I apply light pressure by hand to deflect it a little. Is this normal tension? I am afraid of wearing out cam bearing prematurely.
Can any one help?
Thanks,
rob
tattoo3 09-18-2005 12:38 PM
NAPA???
Thats the way its supposed to be, I know the one you took off had lots of play, but the new one should be tight. it will stretch in just a few miles. I would suggest however that you take it back off until you have all the rotating assembly installed. I prefer to leave everything else alone until each cylinder is finished and fit just perfect. crank rods and pistons are the most important part of the motor.
have fun.
hause 09-18-2005 01:55 PM
I Know That Between The Cam Gear A Crank Gear Put A Striaght Edge On Them And With A Feeler Gauge And See The Clearence. If It To Excessive It Wth Cause Permature Chain Ware Specialy If It's A Roller Cam. I Don't Know The Clearence On Roller Cam Or Flat Tappet But Call Comp Cams They Will Give You Some More Info On This.
Comp Cams Number- 1-901-795-2400
Jmark 09-18-2005 05:57 PM
I've done some that when installed, were as tight as a banjo string while others had a very small amount of movement side to side. Didn't pay it much attention and all of them ran fine, but then again, I wasn't building a funny car engine either.
johnsongrass1 09-19-2005 08:00 AM
The variation comes from crank aligned engines, cam bore resizing, bearing thickness, core shift, as well as manufacturer tolerances on the block and crank.
How tight should it be? I'll call it snug. Anything but floppy.
mouseman 09-19-2005 08:54 AM
ok, that makes me feel a little better. I am going to leave it alone; however, I am going to take the timing chain back off and put pistons and rods in, then put the chain, cam button back on.
johnsongrass1 09-19-2005 02:20 PM
Why? Just more work
mouseman 09-20-2005 08:43 AM
yep, your probably right.
thanks for your help
