Correct timing vs what works question - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-24-2010, 10:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I just saw this, in another thread:
Originally Posted by miles
Has anybody out there put a 871 on a 455 olds. apparently I jump before I did my homework. Here is what I got, 1972 455 olds with J heads remanfactured engine.Casting no 396021F, I run a compression test and it come out to 180 psi which the people at BDS told me is a 11.24.1 compression ratio...
This would seem to agree w/what I remembered, as the 11.24 is derived by subtracting 14.7 from the 180 psi reading the OP had given BDS.
And, no- I didn't read this thread before I posted above. I'm rather anal about citing sources, and this would have been no exception.
  #32 (permalink)
Old 07-24-2010, 10:37 AM
Originally Posted by cobalt327
I just saw this, in another thread:This would seem to agree w/what I remembered, as the 11.24 is derived by subtracting 14.7 from the 180 psi reading the OP had given BDS.
Do I understand right then that my ratio at 175 pounds tested is 10.9-1?
I know I should be able to understand and when I hesr it I'll go "Ah he11 ya" but for the life of me it just wont hit me why you take an atmosphere(14.7) right off the top?But holy frig, that still leaves me with a stiff comp ratio. Maybe thats why no one can believe how strong my 9.75-1 engine runs?
If you do not want to register, fill this field only and the name will be used as user name for your post.
'97 5.7L timing question jjupiter100 Engine 9 04-03-2010 10:22 AM
Timing Question slimcheese Engine 2 03-02-2010 05:02 AM
Timing question - Does this make sense? rajsid Engine 23 01-21-2010 09:23 PM
Question: 84' Caprice Classic Timing Jumps around dlaurie Engine 23 02-18-2008 04:10 PM
Correct Timing Chain Tension mouseman Engine 7 09-20-2005 08:43 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
