Correct timing vs what works question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2010, 01:38 PM
I know this has been brow beat some so I'll keep it short. As I've said before my builder is up my wazzoo every time we talk about NO MORE THAN 36 DEGREES TOTAL!!!! OK thats where its set. Then today I finally get a replacement light for the one that croaked and guess what. Either a lights advance wheel was out, something got moved or whatever I've had a total of 40-41. So quik fast I reset to 36. Go out and do a WOT. Anyone with me may have thought it good if they didnt know the car but I was less than impressed. So aside from what my vac is set at does a fellow leave it at 36 and some how tune other stuff to smarten it up again(If thats even possible)? or does he go back to the 40?compression is 9.75
Old 07-22-2010, 03:07 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
More info on the complete setup ie; engine, tranny, gears, weight of car etc would help if this thread goes further but...If your motor ran well before and did not ping, started easy, idle quality was good, good power etc etc then leave it were it was. The 36 is a number that falls within the bench marks for the SBC total timing without vac advance added in, with the vac added yours could be around 52 total...not bad, so it is not like the motor is going to self destruct at anything over 36, is your builder concerned about warranty or something? and how did you get to the 36 by adjusting the base down or limiting the mechanical advance? what is the base set for?
Old 07-22-2010, 03:36 PM
I'm sure the guys here are getting sick of this BUT
383 SBC
air gap RPM intake
650 AVS edelbrock carb
edelbrock 70cc heads
hypereutectic slugs
comp 270 HR cam
Hedman 1 3/4 headers out to straight 2 1/2
3700 pound car with th350 built by me and 373 gears
Ya its the builder barking that if I come back with a defunked engine I'm on the hook if it was more than 36. God I honestly think sometimes I'm going to put a notch on the intake and distributor at 36. Drive it at 40 and if anything happens for any reason just get my 9/16 out of the glove box and set it to 36.
Oh gee says me to builder, it was on 36 the whole time.I dont have a clue what could have happened.
To answer your question,NO it never pinged,it just went like a frikin hurricane. You wouldnt think that 4or5 degrees would make that much of a difference but man does it ever in mine
Old 07-22-2010, 03:55 PM
Custom10's Avatar
Thanks for posting specs again, was not sure about the "big picture". Well if the only condition to his honoring the build is the 36 degree limit then you have it made, at the risk of playing devils advocate here IMHO set it back to what ever it needs to effectively feed the hurricane without detonation and drive it like you stole it
Old 07-22-2010, 05:15 PM
Just came in from that exact deed. I did notice one thing however, that the vac was a bit stronger on the skinny side of 40, actually around 39 so thats where its at. I struck a comprimise between the overall degrees it wanted and picking up a hair more idle vac which may take away the tiny hair of a lul that I had if I punched it from a stand still. I got er marked at 36 and by gum thats where she'll go back to if sh1t hits the fan. See he had this one guy he built the same deal for accept in a 6200 pound truck hauling a 5000 pound trailer with the timing set at 40 and another full point of compression over me and an engine that ran 20-30 degrees hotter than mine take up a 45 degree hill with that whole mess and go into melt down mode,so now the builders all squirelly when he hears big timing numbers. Builder is very compitant at putting the stuff together but admits that after its together his tuning abilities are strictly race and not street. Thanks for being a sounding board Custom10
Old 07-22-2010, 05:20 PM
Did the balancer ring slip?
With 11:1 compression and old bowtie heads on race gas, we used to routinely run 40-43 degrees locked total, and that was determined on an engine dyno. Some new heads are as little as 28 degrees for peak power.
Old 07-22-2010, 05:33 PM
ericnova72's Avatar
More for Less Racer
Some chamber shapes will like more timing, some(like the Vortec)will like less. You will find that most engine dyno operators will start around 32-36, and then let the engine and the dyno #'s tell you what the engine likes by testing. You are by no means out in left field at 39-40, the aluminum heads have a little more tolerance and may prefer to be a little higher.
Let the engine tell you what it wants rather than trying to bend the engine to your preset notion of what it needs.
It is very common for two different timing lights to read differently, especially the dial back types. Pick one light and use it exclusively, don't borrow a light at the races, it could bite you.
Old 07-22-2010, 05:41 PM
techinspector1's Avatar
Wiki Edits: 326
You're thinkin' what I'm thinkin'. I'm bettin' that what the OP is seein' as 40 degrees is actually somethin' less.
http://www.crankshaftcoalition.com/w...op_dead_center
Old 07-22-2010, 06:09 PM
How does one detect balancer slip?any way other than the whole tdc bit?guess not huh
Old 07-22-2010, 06:26 PM
Wiki Edits: 326
If it was easy, everybody would be doing it.
Old 07-22-2010, 06:27 PM
ericnova72's Avatar
More for Less Racer
Paint a line from the hub to the outer ring, if it moves more you will be able to see it down the road.
Old 07-22-2010, 06:48 PM
I try to remember to index mark the hub to the ring, but i forget sometimes. The balancer people out to do that!
Most engines I build use an ATI.
Old 07-22-2010, 07:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If it is a lot of slip, just comparing the location of the inner damper keyway to the outer camper ring TDC mark will tell you.
Depending on what damper/tab you have, the difference between the keyway and the TDC line will be 2, 10 or 40 degrees. Having the damper off would be the easiest way to see things clearly for measurement.
Another way to look at it, is if the damper mark and tab are aligned at TDC, the keyway should be @ 2 o'clock.
Old 07-22-2010, 08:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't recall if this engine has been "dyno tuned", but if it has, take the timing as a suggestion- very often the underhood heat, coolant temp differences, changes in the ignition systems between the dyno cell and what's in the vehicle, differences in the fuel will all conspire to lower the actual timing needed in the real world to be safe. But if you stay close to 36 (unless this is a fast burn type head), you should be in the ballpark.
Was your builder the one who couldn't get his head around using vacuum advance because it caused too much timing at WOT?
Old 07-23-2010, 06:10 AM
Yes Cobalt. Primarily due to post 5 of this thread
'97 5.7L timing question jjupiter100 Engine 9 04-03-2010 11:22 AM
Timing Question slimcheese Engine 2 03-02-2010 06:02 AM
Timing question - Does this make sense? rajsid Engine 23 01-21-2010 10:23 PM
Question: 84' Caprice Classic Timing Jumps around dlaurie Engine 23 02-18-2008 05:10 PM
Correct Timing Chain Tension mouseman Engine 7 09-20-2005 09:43 AM
