correct tools ring and pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2013, 12:18 PM
what is the 2 tools - dial indicator, and torque wrench item #'s to order thru harbor freight? Also what is the best video, preferably vhs to install new r&p, thanks Dana
Old 10-21-2013, 06:00 PM
big gear head's Avatar
High Performance Rear Ends
You just need a dial indicator with a 1 inch travel and a magnetic base to hold it to the housing. You will also need a 1/4 inch drive torque wrench that measures from 0 to 30 inch pounds to measure pinion bearing preload. I don't know if Harbor Freight will have the torque wrench, but you should be able to find it on ebay.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (10-21-2013)
Old 10-21-2013, 06:17 PM
thought I had to use a torque meter, I miss understand all the posts. thanks for the advice
Old 10-21-2013, 08:29 PM
It must be a dial or beam type, not a clicker.
1930u Correct Ring Installation? 1930u Engine 2 02-19-2011 09:21 PM
Are my ring and pinion still ok? zildjian4life218 Transmission - Rearend 41 09-22-2010 12:25 PM
Need Correct Ring Gap Clearance newdad1 Engine 5 08-28-2007 04:50 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 08:58 AM
Correct Length, Ford Trac Loc Ring Gear Bolts? acr Transmission - Rearend 1 10-13-2004 07:17 AM
