Got a 400SBC and have put the needed brackets and hardware on the front to run a serpentine belt. All the hardware is from a 1992 Camaro with a 5.7L. I bought a water pump for the that application, 92 Camaro, and after threading the belt it looks like the water pump will be turning CCW, if facing the front of the engine, which I believe is the opposite a SBC normally turns. Will this set up cool the 400 and will the water pump be setup to turn CCW??
Thanks.
Thanks.
