correct way to wire gauges - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2009, 02:23 AM
i've had enough of wiring! i used to be good at this crap. got my butt kicked for 3 days chasing a ground issue caused by one tiny wire that backed out of the fuse panel connector. I've got a set of Summit Electric gauges. Fuel Level, Oil Pressure, Engine Temp, and volt. Instructions with the gauges dont really help much so i wired them the way i thought its should work. Each gauge has a 12 positive, Ground wire, Dimmer wire, and ofcourse the signal wire. hooked all the Positive wires together and wired that to a keyed 12volt source. Tied all the grounds together and grounded them to a body bolt. hooked up all the sensors to there respective wire. Turn on the key and all of the gauges are pegged except the voltmeter which is reading the correct battery voltage. So what did i do wrong?
Old 08-12-2009, 04:23 PM
If the connections are not marked, perhaps you have incorrect polarity and/or termination points in you wiring. I believe a fuel gage, for instance, uses the ground for reference, either as full or empty, and the variable resistor in the tank as reference to compare to the ground. If you wired all your grounds to the sensing lines, you might get just the result you did.
Pat
What's the proper way to wire an alternator? 70bird Electrical 18 08-14-2010 01:24 PM
How do I Wire in a Trinary switch kirkschopped67 Electrical 9 01-13-2009 03:59 PM
Starter Problems Jsquier Electrical 5 08-26-2007 06:32 PM
the brown wire comin from the white clip on a chevy blazer altenator?? badk5 Engine 12 06-27-2005 09:23 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 04:39 AM
