Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - correct way to wire ignition and starter, alternator
Old 02-21-2012, 01:36 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Originally Posted by sandmannm575
tried wiring my 1963 ford f100 which now has a 351w from a 1978 model ford, i am attempting to change wiring harness but the wires for ignition switch were cut and couldnt wire it correctly would turn over but will not stay running when key in run postion
Quick answer is when in run the ignition switch needs to supply power to the ignition system. You need to get a meter and a diagram. The 63 most likely has a resistance wire for run and a full battery power feed to the ignition for starting that comes from the solenoid. Sounds like your run wire is not connected.
Chet
