correct way to wire ignition and starter, alternator
tried wiring my 1963 ford f100 which now has a 351w from a 1978 model ford, i am attempting to change wiring harness but the wires for ignition switch were cut and couldnt wire it correctly would turn over but will not stay running when key in run postion
Ford
Ford resistance wire to coil is probably pink in color or pink with a stripe 1963 and 1964 had these as I remember with mine..
Use this to wire the ignition:
http://i70.photobucket.com/albums/i8...Fordwiring.jpg This should work for the charging system: http://i70.photobucket.com/albums/i8...gingsystem.jpg |
| All times are GMT -6. The time now is 11:41 PM. |
