correct way to wire ignition and starter, alternator
tried wiring my 1963 ford f100 which now has a 351w from a 1978 model ford, i am attempting to change wiring harness but the wires for ignition switch were cut and couldnt wire it correctly would turn over but will not stay running when key in run postion
Artificial Intelligence is no match for Natural Stupidity Chet |
Ford
Ford resistance wire to coil is probably pink in color or pink with a stripe 1963 and 1964 had these as I remember with mine..
Use this to wire the ignition:
![]() This should work for the charging system:
| Question on MADD wiring of the starter and alternator charge wire. | grobb284 | Electrical | 18 | 12-31-2011 12:08 AM |
| wire terminal broke off 2-wire alternator | bullheimer | Electrical | 3 | 10-11-2009 10:22 AM |
| One wire alternator to starter post? | Ripped | Engine | 8 | 06-01-2008 12:07 AM |
| Wiring a 1 wire alternator and starter | 71novactb | Electrical | 7 | 02-09-2007 09:14 PM |
| Wire Diagram for points,starter,1 wire alt,and distributor | plainhavoc | Electrical | 3 | 04-12-2006 02:13 AM |
