correcting speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2005, 11:03 AM
how can I correct my speedometer in my 86 chevy four wheeldrive pickup. I changed rearend gears and tire size and it is way off now. It is cable and gear not computer controled.
Old 02-19-2005, 12:00 PM
Fairly simple really.......
Go here............
http://www.tciauto.com/tech_info/speedo_gears.htm
Everything you need to know .........
Deuce
Old 02-19-2005, 11:07 PM
Or www.novaresource.org/speedo.htm
Old 02-20-2005, 09:53 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Or, because this has been covered so many times on here, search for posts on the subject.
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 04:10 PM
Speedometer Problem - Not sure where to put this? Fragzem Transmission - Rearend 6 02-04-2005 02:09 PM
Speedometer gear housing problem guba_unus Transmission - Rearend 1 01-09-2005 07:08 PM
700R4 - Speedometer chev38 Transmission - Rearend 10 05-06-2004 08:00 PM
Speedometer question Jeff69cat Engine 2 09-19-2002 09:41 PM
