Corvair Disc Brake Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2005, 11:37 AM
Has anyone out there done a front disc brake conversion on a 65-69 Corvair using donor parts?
The kits I found are too expensive. They had one kit for the 60-64 Corvair and another for the 65-69. One kit looked ok, but the other kit was REALLY funky looking, and they did not say which kit would fit my car.
I found this 62-67 Chevy II conversion article that is pretty detailed:
http://www.allchevynova.com/nova/discbrake.html
...the A-arms look a lot like the ones on my Corvair, but drums are wider.
I should be able to use the steps in this article for the procedure, but need a (different?) list of parts and which cars they should come from to do the job on the Corvair.
Old 08-23-2005, 05:07 PM
Originally Posted by tcruise
The kits I found are too expensive..
A lot of the time................the more expensive route is the cheapest route in the long run........everything works.....and you don't end up with a abortion...
Old 08-27-2005, 04:33 PM
Cheap alternative
I found a company that makes brackets that work with commonly available disc brake parts, instead of using "custom" brake parts (not sure where they get the brake parts, but I bet they are stock brakes for some GM car):
http://www.scarebird.com/
The brackets cost $75 per pair. You have to supply the brake parts, have the flange on the hubs turned down to clear the rotor hat (I think this is also true for the $475 kit for 65-69 Corvairs with 14" wheels that includes all the brake parts sold by Corvair Underground), replace the studs with longer ones and remove some material from the calipers.
Old 08-31-2005, 12:16 AM
Be advised that many 14" wheels that came on '60s GM drum-brake cars will not clear the calipers on a disc conversion.
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
1956 Pontiac Starchief disc brake conversion lsb Suspension - Brakes - Steering 11 02-28-2006 08:32 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
disc brake conversion BIGBLOCKSTANG Suspension - Brakes - Steering 4 11-22-2002 06:07 AM
