Corvair Engine problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2008, 07:13 AM
I have a 1964 Corvair. It runs great until it gets hot. I think it is vapor locking but can't be sure. Once it cools down it starts right up. I can run on cool days but on hot days it will die and not start again until cool down. I'm sure it is starved for gas since it will run on starting fluid spray even when hot. Help?
Old 06-06-2008, 08:00 AM
techinspector1's Avatar
Wiki Edits: 326
Ummm....change the fuel filter???
Old 06-06-2008, 10:00 AM
Jmark's Avatar
Check fuel pump pressure AND flow. Weak pump will give up when hot.
Mark
Old 06-06-2008, 10:09 AM
Make sure the fuel pump diaphragm isn't leaking too. I've never had vapor lock problems on any of the Corvairs that I've owned. A sure cure for it would be retrofitting a electric fuel pump. The quality of replacement mechanical pumps is terrible anyway.
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
engine hesitating and other problems 68ford Engine 6 08-18-2006 08:12 PM
84 mustang engine idle problems naarman Engine 1 07-22-2006 08:42 AM
84 mustang engine idle problems naarman Transmission - Rearend 1 07-21-2006 08:43 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
