Sounds like fuel pump.........You said gravity feed....Is there not a fuel pump on these?
OK..you said electric fuel pump.......Maybe those small fuel lines are hampering flow.
Ontario Rodders |
Check the pressure on the fuel pump. To much pressure will cause the carbs to flood. Make sure you have the crossover pipe connected and that it doesn''t have any leaks at the hoses. I have rebuilt my carbs several times and still could not get it running right. I finally sent them off to an expert and he sent me back a list of all things I did wrong even when I carefully followed the instructions on the kit. My carbs were flooding so bad I ruined a $45 zero balance guage. Tune up is the same as any chevy. Set the timing to 8 btdc. The trick with these is to balance the carbs. Sounds like you have done that but a syncrometer is not the most accurate way to do it. Use a zero center guage or make one by putting your vacuum guage in a sealed bottle and attaching a fitting to the lid. connect the vacuum guage to one carb and a hose to the fitting to the other carb. You should be showing no pressure on the guage if it is balanced. You may have to reverse hoses to check since the guage stops at zero.
Double check your plugs. Don't use platinum plugs. They fail almost immediately. I use Bosch Supers. Make sure there are absolutely no vacuum leaks. |
Definitely not accelerator pumps. I rebuilt the carbs then replaced them with a used pair that was working on another engine when removed. Timing? I don't know how you check/set that on a corvair. A vw you do it by moving the pulley to 4 or 7 degrees and using a checklight at the coil.
Thanks for all your fast responses so far. I am new to this forum and this is really helpful. Sooner or later, I'll get my projects posted on this site. (two avengers, fiberfab banshee, dune buggy)
This may be late but you can set 0 tdc by setting your timing mark on the damper to 0 making sure you are on #1 cylinder. Remove the #1 plug and reattach the wire. Lay it on the engine were you can see it and it is grounded. With the ignition on turn the distributor until you see spark at the plug. This will set the timing at 0 tdc. You can set it at 8 BTDC by setting the timing at 8 btdc and turn until you get spark. You need to turn the distributor in the direction opposite that the rotor turns so it will be on the front side of the contact like it would if the rotor was turning and not the distributor.
Hope this helps. I don't remember why the platinum plugs fail but they do and in a hurry. Try the Bosch and you won't have any more problems. Let us know if you get it running right. |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| old aircraft engine running | bentwings | Engine | 4 | 02-06-2006 12:06 AM |
| homemade engine troubles | masonmachines | Engine | 36 | 06-09-2004 11:20 AM |
| Engine running hot ???? | GREENTHING | Engine | 16 | 07-03-2003 09:06 AM |
| 74 Vette 350 engine troubles | KnumbKnuts | Engine | 2 | 03-22-2003 03:31 PM |
