corvair engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2006, 02:22 PM
corvair engine swap
Please help me, I have a 1965 corvair and i want to swap the engine for a good v6 like the 4.3gm or something of the sort i would like to keep it carburated and as few wires as posable and the info i need is witch engine rotates the proper way and where can i get an adapter kit for this
Old 03-18-2006, 02:46 PM
poncho62's Avatar
Wiki Edits: 5
Crown and Kelmark used to make adapters for a V8 in the back seat swap in Corvairs. You may be able to find one of those, One company turned the transaxle around, the other did not.
About the direction.......You may be able to flip the ring gear to get the right direction, if it's wrong....not sure. There were a few Corvair guys around here last year....might be looking in.
Old 03-18-2006, 04:59 PM
thats my point
you see thats my point I dont want a v8 just a 6 or even a 4 as long as its dependiable thats what i need if anybody out there knows where i can get this kit please let me know
Old 03-18-2006, 05:21 PM
poncho62's Avatar
Wiki Edits: 5
My point is, that the 4.3 GM uses the same bell housing pattern as the SB v8 Chevy, so it would work for you. I doubt if there were any other adapters available.
Old 03-18-2006, 07:59 PM
well
well then I just might have to have one made for me I think im going to go with a 20r toyota but that depends on the rotation. i would love to go with the 4.3 but i want my back seats to remain were they are
Old 03-19-2006, 06:06 AM
poncho62's Avatar
Wiki Edits: 5
You could still put the motor out back. I remember seeing pictures of Buick Aluminum v8s in the rear of Corvairs in the 60s.
Old 03-19-2006, 02:50 PM
20r yota
does any body know what direction a toyota engine spins
Old 03-19-2006, 07:49 PM
one last ?
I plane on gettine a 22re toyota engine for my corvair providing that it rotates the proper way any having an adapter kit made do go to a machine shop or is there another place that this is more common?
Old 03-19-2006, 07:53 PM
Try this place. http://www.corvair.com/user-cgi/main
They seem to have more Corvair stuff than anybody.
JA
Old 03-19-2006, 08:09 PM
I've always heard that Honda engines rotate backwards, at least the early ones. You may want to research that. The only carbureted Honda engines would be on early models. Kennedy Engineered Products (http://www.kennedyeng.com/) makes adaptors for all kinds of engine/tranny combos.
Old 03-20-2006, 07:16 AM
kep
I look at keps web site and even called them they said that they dont do corvairs anymore
Old 02-25-2009, 11:11 PM
corvair swap
Hi I know I am a bit late to the party, but how about some out of the box thinking? Consider if you will..... A Subaru flat six 2.5 or 3.3L out of a WRX or STi mounted mid-engine style, with an acompanying electronically shifted automatic or a stout 6 speed manual. This would eliminate the weak link corvair Diff and adapting a strange engine to the vair transaxle. The rotational direction conserns, Then other than fabricating an engine cradle you only have to adapt the Subie axles to the existing vair axles. ofcourse you still have all the wiring linkages and plumbing that would come with any other water cooled engine swap. The aluminum engine, low center of gravity and large supply of aftermarket parts is an interesting concept.
Old 03-06-2011, 07:42 PM
Did you try the Crown conversion kit? It adapts the Chevy V-8 to the corvair, and the GM 4.3 (or 4.2L) engine will go directly in there too.
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 04:32 PM
Engine swap for Blazer S10 ducktruck87 Engine 31 07-01-2010 08:44 PM
engine swap for S-10 Andrew7dg Engine 33 04-05-2010 07:08 PM
Engine Swap for Crown Vic edge Engine 12 11-03-2009 09:38 PM
engine swap question earthworm Engine 17 12-08-2003 01:53 PM
