| The Following User Says Thank You to cruzinTLT For This Useful Post: | ||
Valkyrie5.7 (02-19-2013) | ||
Good job on getting that fixed! I had a old ford fairlaine as a first car and had a very similar problem, turned out the battery tie down was lose and the positive post was too close to the body and would randomly short out and kill the engine. In the following years I've found this similar problem on many other cars that had a "randomly dies" issue.
I dont think its electrical if you can pump gas to get it restarted or carb because of dual carbs as John said check fuel line if you have rubber line tnis new gas detoriates the fuel line and the suck together causing fuel starvation,also check fuel tank for debris,, i had a corvair with a leave in gas tank when i would drive it would slosh around and cover pickup tube when engine stalled it would drop to bottom and restart ,Very herd to find
If you read my original post, you'll see that I had addressed all the fuel issues, so I started looking at electrical. The ignition circuit was my next choice, and that's where I found the "boogered-up" wires. Re-taping the wires seemed to do the trick. Thanks for your advice!
Good glad to see you got it fixed ,Now you can drive and enjoy..
| Engine Swap 1963 Corvair Greenbrier | Selier | Engine | 4 | 12-21-2011 02:44 PM |
| Corvair Engine Conversion | Stinger0819 | Engine | 2 | 03-07-2011 02:52 PM |
| corvair engine swap | 65corvair | Engine | 12 | 03-06-2011 07:42 PM |
| Corvair Engine problems | Zelmo | Engine | 3 | 06-06-2008 10:09 AM |
| Corvair engine running troubles | lugog | Engine | 7 | 02-02-2007 02:03 PM |
