Tell us more. When it dies does it start right back up and keep going? Any high temp issues when it dies? Have you given the under-dash wires the jiggle test? While it's running, move them around, gently, especially around the ignition switch, see if it dies or tries to. Are all motor grounds to the frame tight and clean? Does it have a neutral safety switch, maybe on the clutch pedal or trans-axle that's intermittent? (Not a likely problem if it starts...)
Midnight Sun Street Rod Association |
hard start
I've had a couple corvair powered dunebuggies. the first one was next to impossible to restart after setting a few minutes, I used to carry a pump oil squirt can filled with gas and have to give the carbs a shot of gas. On the second one I machined the heads and added more intake carb flanges then built a spider-leg manifold ( like headers in reverse) and ran a single holly truck 2 barrel, I never any problems with the holly. and it would pull the front wheels up in second gear.
More info.
Thanks guys for responding so quickly. When it quits, it seems to "catch" again most of the time when I pump the gas, but that may be just a coincidence, leading me to think it's fuel problems. It does it no matter whether it's warm or cold, so no vapor lock. I haven't tried jiggling wires under the dash yet--I guess that may be my next spot to look. There is no neutral safety switch that I know of, and yes, it does start up and idles fine. The wiring is in good shape as far as i have seen, but I will do some poking around. THANKS!
Years ago I had a Greenbriar van - same corvair engine. The fuel pump on mine was held in place by a jamb bolt on the side of the housing. It would periodically work loose, allowing the entire pump to rise and fall, held primarily by the metal fuel lines. At idle and low rpms, it would pump enough gas to keep it running - when I revved it up more, the pump would rise, and stay there so it wasn't pumping much, if any, gas. Make sure yours isn't loose - it will look fine when the engine is off. Also, periodically check the screws holding the fuel pump together - they have a tendency to loosen, and when they do, it sprays gas all over the top of the engine! That was the first car I ever bought that had two fire extinguishers in it - I should have suspected something!
I will check that bolt--I know what you are talking about. I am very suspicious of the ignition circuit, so I will be checking all the wiring. I wanted to run the problem by the experts on this forum before proceeding further. I'll let you know what I find WHEN I figure this out
![]() HAPPY THANKSGIVING, GUYS And by the way, If you see any veterans during your holiday travels, be sure to thank them for their service!!!
Corvair engine woes
Well that was going to be my suggestion the ignition circuit. What type distributor does it have? If it's points style check the condenser and the pickup coil assembly with a multimeter. If it is an electronic, have the module tested at the Auto Parts store. Check the pickup coil assembly with a multimeter. Check the coil with wires disconnected with a multimeter. First check the resistance between the two side terminals. Reading should be 0.75-0.81 ohms. Then check between the side terminals and the center high output terminal. reading should be 10,000-11,000 ohms. Here is an article to read on HEI distributors. It has how to test parts of the distributor.
Fuel Pump
Rafee corvair .com,has an electrical fuel pump kit,it has all the parts for the install included,price is $89.95 plus shipping,i just ordered one for my 61 monza.it includes the aluminum plug to replace the old fuel pump. (ive owned 9 Corvairs)
I checked the bolt on the fuel pump--it is tight. Appreciate the other suggestion, but I want to stay with the stock fuel pump. I kinda am ruling out fuel issues unless there is trash in the bowls of the carbs. After Thanksgiving I'll get on the wiring check, and then tear down the carbs if nothing shows up in the wiring. Thanks
I apologize if this has been mentioned before, I only skimmed the responses, but have you driven the car while monitoring fuel pressure to see if the pump is acting up? What's the fuel pressure at idle?
John L |
Autozone (or any other box store) should have the tool that you can rent with a deposit and return and get your deposit back. Checking fuel pressure would be the first thing I would do.
| Engine Swap 1963 Corvair Greenbrier | Selier | Engine | 4 | 12-21-2011 02:44 PM |
| Corvair Engine Conversion | Stinger0819 | Engine | 2 | 03-07-2011 02:52 PM |
| corvair engine swap | 65corvair | Engine | 12 | 03-06-2011 07:42 PM |
| Corvair Engine problems | Zelmo | Engine | 3 | 06-06-2008 10:09 AM |
| Corvair engine running troubles | lugog | Engine | 7 | 02-02-2007 02:03 PM |
