Corvair Powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2012, 03:58 PM
Corvair Powerglide
I have always been around hot rodders from the old days and have learned a lot of shop tricks to make things better for little bucks. I have found myself with a new project and parts that I am unfamiliar with. I am working on a 1962 Corvair Greenbriar that has a powerglide trans. I am having the engine built for it but I need to do some work with the tranny and I have been told by one or two people who have never worked on these that they are tha same as any other powerglide internally. If this is so, I can work with it. Are they right? Does anyone have experience with this tranny? I know that Pontiac used these in early Tempest. Can I build it up to be more streetable?
I appreciate any help out there. I am having Rafee build the engine as soon as we find one I want to use. I have three Corvairs and four engine.
Old 03-31-2012, 01:06 PM
Is anybody out there?
Old 03-31-2012, 03:04 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
We are here!! yes as far as I know the Corvair is similar to the regular glide. Check with Hughes performance for parts and such for that..
Sam
Old 03-31-2012, 06:58 PM
Thanks Sam. I was beginning to wonder if I had stumbled onto something
no one knows about. It is a strange set up for a powerglide, but internally, as far as I can tell, should be the same thing. This is buildable. I do appreciate any help, this project is for the wife.
Old 03-31-2012, 07:47 PM
KVP's Avatar
KVP KVP is offline
Corvair powerglide
For Corvair parts and technical info/advice, contact Clark's Corvair Parts in Shelburne Falls, MA. They've been in business for a long time and will be able to help you with your Corvair project needs. They have stock replacement parts and speed parts as well.
Old 03-31-2012, 09:40 PM
Wiki Edits: 85
The Corvair Powerglide is very similar to other PGs, but not everything internally is the same. For example, the pump is not even close to being the same.
Is a Corvair pitman arm the only pitman arm that fits Corvair box? Blublood Suspension - Brakes - Steering 6 03-28-2012 09:58 PM
Corvair 67 and Amx Racing Zorba Introduce Yourself 1 03-16-2012 10:52 AM
Corvair V8 wayne seelig Introduce Yourself 2 06-29-2011 02:20 PM
65 corvair corvairman65 Introduce Yourself 7 09-21-2005 05:59 AM
corvair ifs junkyardjeff Suspension - Brakes - Steering 1 06-14-2004 10:11 PM
