Corvair Steering
I recently bought a 1968 Corvair 500 coupe. It has an aftermarket steering wheel that is about the same diameter as the factory wheel.
PROBLEM: This car is hard to steer/fights on turns. When coming out of the turn, it tries like hell to return to the center position.
It drives totally straight and smooth with no hands on the wheel. The steering and suspension parts look clean and lubed (have not tried lubing yet). Swaybar bushings recently replaced.
It currently has P185/80R13's mounted on all four wheels, front tire pressure is 25 lbs (a bit low). Am planning to replace these with a set of 15" mags and performance tires. The Goodyear TA 60-series fit on the back, but the front tires don't clear the wheel well -- will probably try 70 series on the front.
I'd appreciate any qualified advice on getting the steering problem solved before I start tearing into it.
Thanks!
